AD581,datasheet,pdf(High Preci
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-23
申换换
分享资料个
The AD5811 is a 3-pin, temperature compensated, monolithic, band gap voltage reference that provides a precise 10.00 V output from an unregulated input level ranging from 12 V to 30 V. Laser wafer trimming (LWT) is used to trim both the initial error at +25°C as well as the temperature coefficient, resulting in high precision performance previously available only in expen-sive hybrids or oven regulated modules. The 5 mV initial error tolerance and 5 ppm/°C guaranteed temperature coefficient of the AD581L is available in a monolithic voltage reference.
评论(0)
发评论
下载排行榜
