基于ARM MCU实现先进的视频图形处理能力
系统,需要先进的视频图形功能的实现是一个挑战。传统上,这些系统需要一个复杂的硬件功能和软件功能相结合,创建所需的应用程序所需的更高级别的视频和图形。ARM最新的作物为基础的微控制器提供一整套先进的硬件功能,通常执行常见的视频和图形标准作为独立的模块,最大限度地减少了需要“硬编码”这些硬件的功能。此外,广泛的基于ARM的生态系统提供了一个主机的实现应用程序级别的普通功能的软件支持(例如,轻松构建应用程序的图形用户界面,或GUI)与少量的低级编码需要。广泛的参考设计和硬件平台允许设计人员利用制造商开发的例程,以简化自己的自定义应用程序的创建。让我们看看一些新的视频硬件和软件功能,现在在ARM的MCU家庭。
Three key elements: input, processing, and display
It is convenient to separate the three key video graphics elements into input, processing, and display. The input functions typically allow the device to connect to a variety of sensors and cameras over a wide range of standards. Processing functions support translation of one standard to another, the creation of multi-layer graphics objects for display (for example, as an element in a GUI), and even more complex functions for creating objects with depth and shading attributes. Finally, the display functions convert the graphics elements stored in internal memory into data that can be transmitted to a flat- panel display or a TV. Let’s now look at each of these elements in more detail, using example ARM-based MCUs.
