无线电机监测传感器扫频振动能量
能量采集可以在监控传感器所需的无线传感器上发挥特别有用的作用。通过采集电机运行固有的振动能量,无线传感器可以实现电机运行的零功率性能和寿命。工程师可以利用各种可用的传感器、微控制器、无线IC加速零功耗无线传感器的设计和生产的产品开发,包括Cymbet,线性技术、芯片技术、美迪科技开发包,德克萨斯文书,其中。
尽管电动机故障可能由于多种原因而发生,但它们通常会逐渐发生,并随着时间的推移发出警告信号。随着温度的变化,典型电机的振动特性提供了电机性能和最终故障的有用指标(图1)。
Figure 1: A motor‘s operating characteristics are reflected in its frequency characteristics as seen in the shift in the frequency-domain signature of a simple DC motor operating with no load (a) and under load (b)。 (Courtesy of Freescale Semiconductor.)
By monitoring changes in a motor’s performance and operating characteristics, engineers can predict a wide range of mechanical failures well before the motor stops functioning. As a result, factory operators can replace motors before catastrophic failures might stall factory operations or even create life-threatening situations.
