LED路灯驱动解决方案简化设计
由于电力、维修和更换费用,路灯往往是市政当局最高的运营费用之一。因此,处理像路灯这样的大功率灯具对于设计者来说是一个挑战,因为他们希望简化和降低照明设备的成本。由于LED照明灯具的移动主要是由节约能源所驱动的,LED驱动器的效率是另一个关键问题,因为对LED照明设备的状态监控的需求日益增长。
LED驱动IC制造商在以下几个方面对这些问题作出了回应。一种方法是开发解决方案,将单个组件中的几个被动组件集成起来,以简化设计过程。它们还使设计者更容易平衡多线程解决方案中的当前问题,并包含诸如调光、测光和故障状态等高级功能。
在一个例子中,LED驱动器消除了降压变压器在电压转换中的需要,简化了电源转换为更低的电压。在另一种情况下,一个高度集成的LED驱动器只需要两个无源元件,一个电阻和一个电容器来驱动一串发光二极管。
LED driver manufacturers say the most common power supply used for multi-string streetlights are 48 V AC/DC power supplies that supply constant current. However, there are several choices of LED drivers that also can be used in these applications including switch-mode LED drivers and linear LED drivers.
Because there are several flavors of IC drivers, the right choice for streetlights rests partly with an OEM‘s capability – that is, if it can build an AC/DC power supply solution on its own or if it needs to buy an off-the-shelf product. A designer’s preference also plays a significant role.
