大电流高亮度LED简化电源解决方案
用于主流照明的LED比以前几年前更明亮,能够驱动更高的驱动电流。这意味着照明设备(灯具)需要较少的芯片,以减轻设计者的压力,这些设计者以前不得不拿出复杂的电源单元(“驱动程序”)来提供长串的暗淡的LED。
本文演示了电源需求是如何变化的,然后研究了新一代的集成、高效、紧凑的LED驱动器,非常适合于为现代灯具供电。
增强发光二极管驱动电流
在高亮度LED的早期,“标准”的配置被称为瓦的装置,所谓的因为它是典型的正向电流驱动(如果)350毫安,和标称的正向电压(VF)的3.3至3.5 V(对功耗约为1.2瓦)。但芯片的功效远不及目前令人印象深刻的设备高;单个LED可能产生50流明。
推荐照度级办公室工作,例如,在200到400力士¹。(力士是衡量单位面积光通量。)灯具,随着1000流明输出分布在2.5米左右²区,生产400力士。用前一代芯片制造这种灯具需要20个发光二极管。这是一个复杂的组件,具有挑战性的热管理和电源问题。
Two things have happened to make things easier. First, efficacies have dramatically improved (see the TechZone article LED Efficacy Improvement Shows No Signs of Slowing) such that 1-Watt devices can output over 100 lumens. Second, devices can be safely driven at higher currents – for example, 700 mA up to 5 A – while still keeping the forward voltage in the 3 to 12 V range²。 Although working at these higher currents impacts efficacy due to phenomena such as “efficiency droop” (see the TechZone article Identifying the Causes of LED Efficiency Droop), luminous flux is considerably boosted.
For example, Cree’s X-Lamp XM-L (Figure 1) can produce up to 581 lm (If = 2 A, Vf = 6 V, efficacy = 48 lm/W)。 This device is typical of the modern breed of LEDs.
