电源模块上的保证金和预偏置启动特色重点
新的应用程序和系统往往有多个电压功率数字信号处理器(DSP)、微控制器(µCS),现场可编程门阵列(FPGA),和专用集成电路(ASIC),现代电源设计必须能够控制如何以及何时这些电压斜坡到最终值后的力量开关被激活。
在许多情况下,这些电源也需要能够进入负载中存在的电压。一些设计将要求电源能够在最终测试或特定时间修改其输出,以测试系统的最坏情况下电压、电流和功率负载的规定容差。
许多电源模块设计人员将这些解决方案集成到产品中。电源管理集成电路解决方案也可集成到一个芯片中的一个或多个这些功能。在这篇文章中,我们将集中于集成设计解决方案的电源模块。
Margining
In order to test a power supply’s robustness in the face of supply voltage fluctuations, the load circuit should be dynamically tested over its worst case supply voltage range—this capability is defined as margining¹。 Typically, this function is used during the manufacturing phase of telecommunications, storage, networking and server equipment so that future reliability of these systems can be assessed.
Some ways this is accomplished in the dc/dc converter regulator portion of the power module is to adjust the output voltage levels by altering the feedback loop with a digital-to-analog converter (DAC) usually through a digital interface bus.
