智能现代传感器的数字通信
当传感器位于MCU的某个距离时,通信就成了问题。由汽车工业开发的两个现代传感器协议解决了这些问题,并更好地利用了新的传感器IC拓扑结构。
从传感器早期就已经报道了传感器信号的问题。事实上,如果信息无法显示、通信或共享,那么检测一个参数是没有意义的。
最初,信号或多或少地被机械地和局部地报告了。例如,一个弹簧管压力表,压力表,直接测量的压力通过移动箭头连接管和指向刻度上的固定在框架报告。水银温度计通过水银柱的长度报告感测的温度。
然而,为了远程处理信息或在闭环系统(传感器和控制)中使用传感器,必须以电信号的形式获取传感信息。基于这种观点,在先前提到的压力计中加入了一个机械转换器,以实现一个真正的传感器,不管有没有本地信号调理。
Other types of sensors have an output which can be directly processed electrically. For example, a thermistor is a resistor in which resistance varies with temperature. The resistance of a piezoresistive strain-gauge changes with the strain due to the applied pressure. Those variable resistors are introduced in a Wheatstone bridge providing an electrical voltage that is usually locally conditioned prior to being transmitted further. A rotary potentiometer (resistive divider), used as an angular position sensor, or a variable reluctance magnetic sensor, used as a rotary speed sensor, directly transmits an output voltage without specific signal conditioning.
