对于普瑞光学考虑LED阵列
不管你选择的LED照明光源有多好,你的产品设计只能和它的光学一样好。本文将这些考虑纳入了重点。
Bridgelux家族的LED阵列产品提供高性能,结构紧凑,并为通用照明市场性价比的固态照明解决方案。这些产品结合了LED的高效率,寿命和可靠性的好处与许多传统照明光源的光输出水平。
普瑞LED阵列被设计独特的生产顺利,朗伯发光模式适用于各种照明应用。然而,有些应用程序可能需要不同的光分布。第二光学元件如透镜、反射镜、或准直器可以用来制造各种各样的以光学效应来满足特定的灯和灯具的设计要求。
The purpose of this article is to provide a general understanding of basic optical concepts which can be used to modify the spatial light distribution produced by Bridgelux LED Arrays, and guidance as to how to change the light distribution to meet application driven requirements. Included in this article is an overview of geometric optics, a description of Bridgelux LED Array optical performance, and guidelines for specifying optical performance requirements.
