低压差稳压器L4993数据手册
消耗积分:0 | 格式:rar | 大小:0.96 MB | 2017-09-01
分享资料个
  Description The L4993 is a monolithic integrated 5V Voltage regulator with a low drop voltage at currents up to 150 mA.The output voltage regulating element consists in a p-channel MOS and the regulation is performed regardless of input voltage transients up to 40V. The high precision of the output voltage is obtained with a pre-trimmed reference voltage. The L4993 is protected against short circuit and an over-temperature protection switches off the device in case of extremely high power dissipation. The L4993 watchdog is active when the Enable is high. State of the art features like reset and watchdog make this device particularly suitable to supply microprocessor systems in automotive applications.
低压差稳压器L4993数据手册
评论(0)
发评论
下载排行榜
