Description The TS93x (single, dual and quad) series are operational amplifiers that can operate with voltages as low as 2.7 V and reach a 2.9 Vpp output swing with RL = 100 kΩ when supplied at 3 V. Offering a typical consumption of only 20 μA, these devices are particularly well suited to battery powered applications. The amplifiers space saving 5-pin SOT23-5 package with outer dimensions of 2.8 mm x 2.9 mm make them very easy to implement on a board design.
Features Rail-to-rail output voltage swing Micropower consumption (20 μA) Single supply operation (2.7 to 10 V) Low offset (2 mV max. for TS93xB) CMOS inputs Ultra low input bias current (1 pA) ESD protection (2 kV) Latch-up immunity (class A) Available in SO-8, SO-14, SOT23-5, and TSSOP-14 package Automotive grade
