Description The TS94x (single, dual and quad) series are operational amplifiers characterized for 2.5 V to 10 V operation over a -40° C to +85° C temperature range. They exhibit excellent consumption -1.2 µA, while featuring 10 kHz gain bandwidth product, 1.5 mA output capability and output rail-to-rail operation - 2.85 V typical at 3 V with RL=10 kΩ。 The TS94x op-amps are ideal for battery-powered systems, where very low supply current and output rail-to-rail are required. Their very low - 1 pA typical input bias current and constant supply current over supply voltage enhance the devices’ performance near the end of the battery charge or battery life.
