Everything defined in this section will be common to the two cashless devices – only the addresses will be different.
Unless otherwise stated, all monetary values used by the cashless devices and the VMC will be sixteen bit (Level 01 & 02) or thirty-two bit (Level 03 if 32 bit option enabled), unsignedbinary numbers. The numbers will be sent most significant byte first and scaled using theparameters provided by the cashless device’s READER CONFIGURATION DATA response.
