1.1v至5.5V的摆率控制的负荷开关SiP32408, SiP32409
消耗积分:0 | 格式:rar | 大小:0.24 MB | 2017-09-11
分享资料个
  DESCRIPTION SiP32408 and SiP32409 are slew rate controlled load switches designed for 1.1 V to 5.5 V operation. These devices guarantee low switch on-resistance at 1.2 V input. They feature a controlled soft-on slew rate of typical 2.5 ms that limits the inrush current for designs of heavy capacitive load and minimizes the resulting voltage droop at the power rails. SiP32408 and SiP32409 feature a low voltage control logic interface (On/Off interface) that can interface with low voltage control signals without extra level shifting circuit. Both SiP32408 and SiP32409 have exceptionally low shutdown current and provide reverse blocking to prevent high current flowing into the power source. SiP32409 integrates a output discharge circuit for fast turn off. Both SiP32408 and SiP32409 are available in TDFN4 package of 1.2 mm by 1.6 mm.
评论(0)
发评论
下载排行榜
