标准整流模块VUO98-12NO7
消耗积分:0 | 格式:rar | 大小:0.14 MB | 2017-09-21
分享资料个
  Package with DCB ceramic ● Improved temperature and power cycling ● Planar passivated chips ● Very low forward voltage drop ● Very low leakage current
  Diode for main rectification ● For three phase bridge configurations ● Supplies for DC power equipment ● Input rectifiers for PWM inverter ● Battery DC power supplies ● Field supply for DC motors
  Industry standard outline ● RoHS compliant ● Soldering pins for PCB mounting ● Height: 9 mm ● Base plate: DCB ceramic ● Reduced weight ● Advanced power cycling
标准整流模块VUO98-12NO7
评论(0)
发评论
下载排行榜
