● Package with DCB ceramic ● Improved temperature and power cycling ● Planar passivated chips ● Very low forward voltage drop ● Very low leakage current
Diode for main rectification ● For three phase bridge configurations ● Supplies for DC power equipment ● Input rectifiers for PWM inverter ● Battery DC power supplies ● Field supply for DC motorsIndustry standard outline ● RoHS compliant ● Soldering pins for PCB mounting ● Height: 9 mm ● Base plate: DCB ceramic ● Reduced weight ● Advanced power cycling
