cvfd20065a碳化硅肖特基二极管
消耗积分:0 | 格式:rar | 大小:0.89 MB | 2017-09-21
分享资料个
  650-Volt Schottky Rectifier • Reduced VF for Improved Efficiency • High Humidity Resistance • Zero Forward and Reverse Recovery Voltage • Temperature-Independent Switching Behavior • Extremely Fast Switching • Positive Temperature Coefficient on VF
  Replace Bipolar with Unipolar Rectifiers • Essentially No Switching Losses • Higher Efficiency • Reduction of Heat Sink Requirements • Parallel Devices Without Thermal Runaway
  Power Inverters • Motor Drives • EV Chargers • Power Factor Correction • Server Power Supplies
评论(0)
发评论
下载排行榜
