Analysis of a Self Turn-on Phe
消耗积分:2 | 格式:rar | 大小:344 | 2009-11-26
靓仔峰
分享资料个
Analysis of a Self Turn-on Phenomenon on the Synchronous Rectifier in a DC-DC Converter:In the buck converter with MOS Fets, the low side switch,
which must be still in cutoff state, becomes turn-on when the
high side switch is turned-on and the current flows through the
circuit of the power supply, the high side switch and the low side
switch. We call this phenomenon self turn-on. The power
dissipation by this current becomes higher when the switching
frequency of the converter is high as MHz. This self turn-on
occurs easily in the converter of low output voltage and high
voltage conversion ratio.
We present the principle of self turn-on phenomenon on
circuit simulation and experimental results.
评论(0)
发评论
下载排行榜
