Field-Effect Transistors
消耗积分:3 | 格式:rar | 大小:2455 | 2009-11-26
李鸿洋
分享资料个
Field-Effect Transistors:MOSFETs are 3-terminal devices characterized by a conductive channel (either
p-type or n-type semiconductor) between 2 of the terminals (called source &
drain), through which the current flow is controlled by an electric field due to an
voltage applied to the 3rd terminal (called gate). The gate is insulated from the
conducting channel—in fact, MOSFETs are sometimes called "Insulated-Gate
FETs" or IGFETs—this blocked gate terminal results in a very high input impedance
which is one of the most advantageous features of these devices over BJTs.
评论(0)
发评论
下载排行榜
