黄光LED技术资料 KPPA-3010SYCK 今台
消耗积分:0 | 格式:pdf | 大小:725KB | 2017-09-28
h1654155970.8622
分享资料个
KPPA-3010SYCK kingbright 今台LED 3.0*2.5*1.0mm 发光二极管
  1. The information included in this document reflects representative usage scenarios and is intended for technical reference only. 2. The part number, type, and specifications mentioned in this document are subject to future change and improvement without notice. Before production usage customer should refer to the latest datasheet for the updated specifications. 3. When using the products referenced in this document, please make sure the product is being operated within the environmental and electrical limits specified in the datasheet. If customer usage exceeds the specified limits, Kingbright will not be responsible for any subsequent issues. 4. The information in this document applies to typical usage in consumer electronics applications. If customer‘s application has special reliability requirements or have life-threatening liabilities, such as automotive or medical usage, please consult with Kingbright representative for further assistance. 5. The contents and information of this document may not be reproduced or re-transmitted without permission by Kingbright. 6. All design applications should refer to Kingbright application notes available at notes
评论(0)
发评论
下载排行榜
