The AS1329A, AS1329B and the AS1322C are synchronous, fixed frequency, very high-efficiency DC-DC boost converters capable of supplying 3.3V at 160mA from a single AA-supply. Compact size and minimum external parts requirements make these devices perfect for modern portable devices.
High-speed switching frequency (1.2MHz) and internally compensated PWM current mode design provide highly-reliable DC-DC conversion, especially when driving white LEDs.
The converters are available as the standard products
| Model | Light Load Switching |
AS1329A |
Powersave Operation (medium loads) |
AS1329B |
Powersave Operation (light loads) |
AS1329C |
Continuous Switching |
The devices contain two internal MOSFET switches: one NMOS switch and one PMOS synchronous rectifier.
Anti-ringing control circuitry reduces EMI by damping the inductor in discontinuous mode, and the devices exhibit extremely low quiescent current (< 1μA) in shutdown.
In shutdown mode the battery is connected directly to the output enabling the supply of real-time-clocks.
The AS1329 is available in a 6-pin TSOT-23 package.声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容侵权或者其他违规问题,请联系本站处理。 举报投诉
