The Vivado™ Design Suite is a new IP and system-centric
design environment that accelerates design productivity fo
the next decade of All-Programmable devices.
All-Programmable devices go beyond programmable logic
and I/O, integrating various combinations of 3D stacked
silicon interconnect technology, software programmable
ARM® processing systems, programmable Analog Mixed
Signal (AMS), and a significant amount of
intellectual-property (IP) cores. These next generation devices
enable designers to go beyond programmable logic to
programmable systems integration, to incorporate more
system functions into fewer parts, increase syste
performance, reduce system power, and lower BOM cost.
Built from the ground up over the last 4 years, the Vivado
Design Suite attacks the key design bottlenecks in
programmable systems integration and implementation to
enable up to a 4X productivity advantage over competing
development environments. For traditional logic-centri
FPGAs, it also enables designs to be created more easily, meet
timing more quickly, and automate—not dictate—the
developer‘s preferred design flow.
