Linux下即插即用设备的安装
消耗积分:1 | 格式:rar | 大小:0.2 MB | 2017-11-07
分享资料个
即插即用,在Linux底下?不好办,你还是换老的非即插即用设备吧。这是我初次接触Linux时,那些Linux高手们告诉我的。可是,我觉得总该有办法的。经过不懈的努力,我发现了两种方法。一是先从DOS启动,初始化设备后,再用loadlin加载到Linux中。但这不是我所梦寐以求的,因为每次需要大量时间来启动。我继续不停的寻找,终于有一天,我找到了我需要的东西,一个称为isapnptools的应用程序。
  现在,大多数发行套件中都有isapnptools。如果你的套件中有,安装它即可。如果你的发行套件中没有它,到http://www.roestock.demon.co.uk/isapnptools/ 去下载一份,解压后把isapnp 和 pnpdump 拷贝到目录 /sbin中即可。
  下面就是实战阶段了。需要准备的就是把你所有要装的即插即用设备全部装好,以ROOT身份登陆。然后运行以下命令/sbin/pnpdump 》 /etc/isapnp.conf,这会把你机器上所有的即插即用设备信息写入文件/etc/isapnp.conf中,下面是我的机器上的/etc/isapnp.conf文件的一部分:
  # $Id: plugnplay.html,v 1.1.1.1 1998/12/26 04:41:14 jack Exp $
  # This is free software, see the sources for details.
  # This software has NO WARRANTY, use at your OWN RISK
  # For details of this file format, see isapnp.conf(5)
  # For latest information on isapnp and pnpdump see:
  # http://www.roestock.demon.co.uk/isapnptools/
  # Compiler flags: -DREALTIME -DNEEDSETSCHEDULER
  # Trying port address 0203
  # Board 1 has serial identifier c5 c0 7f 53 05 01 22 05 07
  # Board 2 has serial identifier 5a 80 86 00 01 20 00 a8 65
  # Board 3 has serial identifier e8 46 46 46 46 90 30 72 56
  # (DEBUG)
  (READPORT 0x0203)
  (ISOLATE PRESERVE)
  (IDENTIFY *)
  (VERBOSITY 2)
  (CONFLICT (IO FATAL)(IRQ FATAL)(DMA FATAL)(MEM FATAL)) # or WARNING
  # Card 1: (serial identifier c5 c0 7f 53 05 01 22 05 07)
  # Vendor Id AXE2201, Serial Number 3229569797, checksum 0xC5.
  # Version 1.0, Vendor version 0.0
  # ANSI string --》Ethernet PnP ISA Card /S 《--
  # Logical device id AXE2201
  # Device support I/O range check register
  # Edit the entries below to uncomment out the configuration required.
  # Note that only the first value of any range is given, this may be
  # changed if required
  # Don‘t forget to uncomment the activate (ACT Y) when happy
  (CONFIGURE AXE2201/3229569797 (LD 0
  # Compatible device id PNP80d6
  # Logical device decodes 10 bit IO address lines
  # Minimum IO base address 0x0240
  # Maximum IO base address 0x0380
  # IO base alignment 32 bytes
  # Number of IO addresses required: 32
  # (IO 0 (SIZE 32) (BASE 0x0240))
  # IRQ 3, 5, 9, 10, 11, 12 or 15.
  # High true, edge sensitive interrupt
  # (INT 0 (IRQ 3 (MODE +E)))
  # (ACT Y)
  # End tag.。. Checksum 0x00 (OK)
  # 略去声卡部分
  #略去modem卡部分
  # Returns all cards to the “Wait for Key” state
  (WAITFORKEY)
  我的系统中共有三个即插即用设备,分别是NE2000兼容网卡,Yamaha OPL~SA2声卡和一个USR 56K modem。由于文件太长,我略去了声卡和modem部分。
  接下来就是为每个设备分配所需资源。有许多方法可以实现。第一种,也是最简单的方法就是,如果你在同一台机器上也装了WIN95或WIN98,通过控制面板的系统的属性页,可以看到在WINDOWS系统下各即插即用设备的资源,记下用到Linux即可。如果你的机器中没有其它的操作系统,采用第二种方法。即手动分配资源,只要各设备资源不发生冲突就行。手动分配资源以前,最好先看一下已经使用的中断列表、I/O列列表,它们分别位于/proc/interrupts、/proc/ioports、/proc/dma。一旦你确定了各设备使用的资源,就可以分配了。
  选择分配给每个设备的资源非常简单。你只要去掉你的设备所需资源前的注释号即可。描述资源的行很容易找到,因为它们总是以INT, IO或 DMA开头。在这些行之前是你所能使用资源的描述。你可以选一组,因为象下面这样的一行说明它们有优先权的区别。
  # Start dependent functions: priority preferred
  在去掉所需资源的注释号后,你还必须去掉(ACT Y)行上的注释号来告诉ISAPNP激活该设备。
  下面是我的/etc/isapnp.conf经过编辑并去掉注释行后的样本:
  READPORT 0x0203)
  (ISOLATE PRESERVE)
  (IDENTIFY *)
  (VERBOSITY 2)
  (ACT Y)
  (CONFIGURE YMH0020/2156265473 (LD 0
  (IO 0 (SIZE 16) (BASE 0x0220))
  (IO 1 (SIZE 8) (BASE 0x0530))
  (IO 2 (SIZE 4) (BASE 0x0388))
  (IO 3 (SIZE 2) (BASE 0x0330))
  (IO 4 (SIZE 2) (BASE 0x0370))
  (INT 0 (IRQ 5 (MODE +E)))
  (DMA 0 (CHANNEL 0))
  (DMA 1 (CHANNEL 1))
  (ACT Y)
  (CONFIGURE YMH0020/2156265473 (LD 1
  (IO 0 (SIZE 1) (BASE 0x0201))
  (NAME “YMH0020/2156265473[1]{OPL3-SA2 Sound Chip }”)
  (ACT Y)
  (CONFIGURE USR3090/1179010630 (LD 0
  (IO 0 (SIZE 8) (BASE 0x02f8))
  (NAME “USR3090/1179010630[0]{U.S. Robotics 56K Voice INT}”)
  (ACT Y)
  (WAITFORKEY)
  如果喜欢,留着其余的注释也行。下一步就是测试你的配置是否正确。使用以下命令/sbin/isapnp /etc/isapnp.conf,屏幕会出现一些信息,样本如下:
  Board 1 has Identity c5 c0 7f 53 05 01 22 05 07: AXE2201
  Serial No 3229569797 [checksum c5]
  Board 2 has Identity 5a 80 86 00 01 20 00 a8 65: YMH0020
  Serial No 2156265473 [checksum 5a]
  Board 3 has Identity e8 46 46 46 46 90 30 72 56: USR3090
  Serial No 1179010630 [checksum e8]
  如果你的配置文件有问题或发生资源冲突,它就会告诉你。发生问题不要着急,从头慢慢查找原因,一步一步再来。如果一切平安无事,你还必须保证你的即插即用设备在启动时能进行认证。不幸的是许多发行套件的初始脚本执行方式不同。如果你的发行套件中有isapnptools的话,可能你已经有正确的初始脚本。如果没有,仿照/etc/rc.d/init.d中的格式,自己写一个。
  最后一步是让你的内核支持即插即用设备。目前,内核支持isapnp设置的即插即用设备的唯一方法是把它们编译为模块。所以,对每一个被认为是即插即用的设备,确信把它编译为内核支持的模块。
  好了,不用再为你的新的设备不能被Linux接受而烦恼了,去尽情享受Linux带给你的乐趣吧。
评论(0)
发评论
下载排行榜
