爱普生SG-8101CA可编程晶振具有CMOS输出X1G005191012100
消耗积分:0 | 格式:docx | 大小:215.20 KB | 2024-09-30
Piezoman压电侠
  • 914内容
  • 95w+阅读
  • 69粉丝
爱普生品振SG-8101系列,是具有CMOS输出的可编程晶体振荡器系列。它们还具有更宽的工作温度范围,上限为105℃。除了2.5x2.0mm封装有助于电子制造商节省电路板空间之外,这些晶体振荡器还提供以下常见封装尺寸:3.2x2.5mm、5.0x3.2mm和7.0x5.0mm。SG-8101系列中的振荡器的频率容差约小66% 电流消耗比同类产品低50%,可在各种环境条件下使用。这也将大大有助于提高性能、降低功耗要求、缩短开发周期和实现小批量生产。
特征:
石英晶体振荡器(可编程)
输出频率:0.67MHz至170MHz(1x10-6步进)输出:CMOS
电源电压:1.62V至3.63V
频率容差、工作温度:15x10-6/-40℃至+85℃℃,20x10-6、50x10-6/-40℃至+105°℃
石英可编程(Q MEMS)具有高稳定、高精度等优越性能的石英材料[QUARTZ]和[MEMS]组合而成的造词,以石英为原料进行精微加工(光刻)并可以提供的小型化、高性能的晶体元器件被称为[Q MEMS]。应用于5G-WIFI6、物联网通讯、钟表。车载导航、智能手机、对讲机、数码产品,光电技术等通讯设备及各种频率控制设备。
产品编码频率贴片晶振尺寸(长宽高)输出波电源电压工作温度
X1G00519100110032.507937 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85°C
X1G00519100120060.000000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 105℃
X1G005191001300100.000000
MHz
X1G00519100140080.000000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85 ℃
X1G00519100150048.000000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V40 to 85 ℃
X1G00519100160027.500000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85℃
X1G00519100170022.500000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85°C
X1G00519100180073.333700 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85°C
X1G00519100190060.000300 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85 ℃
X1G00519100200022.000000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85°C
X1G00519100210018.000000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85℃
X1G00519100220025.000000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V40 to 85 ℃
X1G00519100230069.120000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85°C
X1G0051910024005.560000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 105℃
X1G00519100250066.666000 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 85°C
X1G00519100260013.516800 MHzSG-8101CA7.00x5.00x1.40mmCMOS1.620 to 3.630V-40 to 105 ℃
评论(0)
发评论
下载排行榜
