开源硬件-PMP30232.1-具有 12V/2A 最大输出的微型 SEPIC PCB layout 设计
消耗积分:0 | 格式:pdf | 大小:260.79KB | 2017-12-12
laisvl
分享资料个
The PMP30232 reference design operates at an input voltage range of 6V to 18V. Cranking is possible for voltages as low as 5V and load dump for voltages to 36V. The output voltage is 12V @ 2A. This reference design uses the SEPIC topology as a cost effective alternative for 4 switch buck-boost (...)
评论(0)
发评论
下载排行榜
