HS-303BRH pdf datasheet
消耗积分:5 | 格式:rar | 大小:777 | 2008-08-05
张国厚
分享资料个
The HS-303ARH and HS-303BRH analog switches are monolithic devices fabricated using Intersil抯 dielectrically isolated Radiation Hardened Silicon Gate (RSG) process technology to insure latch-up free operation. They are pinout compatible and functionally equivalent to the HS-303RH, but offer improved 300kRAD(Si) total dose capability. These switches offers low-resistance switching performance for analog voltages up to the supply rails. 揙N?resistance is low and stays reasonably constant over the full range of operating voltage and current. 揙N?resistance also stays reasonably constant when exposed to radiation. Break-before-make switching is controlled by 5V digital inputs. The HS-303ARH should be operated with nominal ?5V supplies, while the HS-303BRH should be operated with nominal ?2V supplies.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
