74HC05 pdf datasheet
消耗积分:3 | 格式:rar | 大小:44 | 2008-08-06
84784
分享资料个
General Description
The MM54HC05/MM74HC05 are logic functions fabricated
by using advanced silicon-gate CMOS technology, which
provides the inherent benefits of CMOSÐlow quiescent
power and wide power supply range. These devices are
also functionally and pin-out compatible with standard
DM54LS/DM74LS logic families. The MM54HC05/
MM74HC05 open drain Hex Inverter requires the addition of
an external resistor to perform a wire-NOR function.
All inputs are protected from static discharge damage by
internal diodes to VCC and ground.
评论(0)
发评论
下载排行榜
