74HC688 pdf datasheet
消耗积分:3 | 格式:rar | 大小:133 | 2008-08-06
万物死
分享资料个
MM54HC688/MM74HC688
8-Bit Magnitude Comparator (Equality Detector)
General Description
This equality detector utilizes advanced silicon-gate CMOS
technology to compare bit for bit two 8-bit words and indicates
whether or not they are equal. The PeQ output indicates
equality when it is low. A single active low enable is
provided to facilitate cascading of several packages and enable
comparison of words greater than 8 bits.
This device is useful in memory block decoding applications,
where memory block enable signals must be generated
from computer address information.
The comparator's output can drive 10 low power Schottky
equivalent loads. This comparator is functionally and pin
compatible to the 54LS688/74LS688. All inputs are protected
from damage due to static discharge by diodes to VCC
and ground.
Features
Y Typical propagation delay: 20 ns
Y Wide power supply range: 2±6V
Y Low quiescent current: 80 mA (74 Series)
Y Large output current: 4 mA (74 Series)
Y Same as 'HC521
评论(0)
发评论
下载排行榜
