54LS367A/DM54LS367A/DM74LS367A Hex TRI-STATEÉ Buffers General Description This device contains six independent gates each of which performs a non-inverting buffer function. The outputs have the TRI-STATE feature. When enabled, the outputs exhibit the low impedance characteristics of a standard LS output with additional drive capability to permit the driving of bus lines without external resistors. When disabled, both the output transistors are turned off presenting a high-impedance state to the bus line. Thus the output will act neither as a significant load nor as a driver. To minimize the possibility that two outputs will attempt to take a common bus to opposite logic levels, the disable time is shorter than the enable time of the outputs. Features Y Alternate military/aerospace device (54LS367A) is available. Contact a National Semiconductor sales office/ distributor for specifications.
