54LS368A/DM54LS368A/DM74LS368A Hex TRI-STATEÉ Inverting Buffers General Description This device contains six independent gates each of which performs an inverting buffer function. The outputs have the TRI-STATE feature. When enabled, the outputs exhibit the low impedance characteristics of a standard LS output with additional drive capability to permit the driving of bus lines without external resistors. When disabled, both the output transistors are turned off presenting a high-impedance state to the bus line. Thus the output will act neither as a significant load nor as a driver. To minimize the possibility that two outputs will attempt to take a common bus to opposite logic levels, the disable time is shorter than the enable time of the outputs. Features Y Alternate Military/Aerospace device (54LS368) is available. Contact a National Semiconductor Sales Office/ Distributor for specifications.
