Hamilton日出日落说明书
消耗积分:2 | 格式:rar | 大小:6933 | 2010-01-20
吴湛
分享资料个
Hamilton日出日落说明书.pdf
Congratulations
Hamilton is delighted that you have chosen a timepiece from its collection. You have acquired a small
technological marvel that will serve you faithfully for many years. The most advanced technologies were
used throughout its manufacture and it underwent stringent controls before it was released for sale.
Care and Maintenance
Recommendations
Like all micro-mechanical precision instruments, your Hamilton watch should be checked at least once every two
years. Entrust your watch only to an authorized Hamilton agent. To keep your watch water-resistant, make sure
that its sealing features are tested at every check-up.
Your watch has an automatic movement. The mechanism of the watch includes an oscillating rotor that winds the
mainspring via the motion of your wrist. The running reserve is approximately 42 hours. If necessary, the watch
may be rewound manually. The beauty of the inner working of the watch movement can be admired through the
transparent case back.
Your watch is water-resistant to a depth of 20 ATM = 200 meters = 660 feet.
Five basic rules for maintaining the water-resistance of your watch
1. Have your watch checked regularly.
2. Do not move the crown when you are in water.
3. Rinse off your watch with fresh water after any immersion in seawater.
4. Dry your watch whenever it gets wet.
5. Have your watch checked for water-resistance by an authorized Hamilton agent each time the case is
评论(0)
发评论
下载排行榜
