TC105 pdf datasheet
消耗积分:2 | 格式:rar | 大小:555 | 2008-08-07
分享资料个
The TC105 is a step-down (Buck) switching controller
that furnishes output currents of up to 1A (max) while
delivering a typical efficiency of 92%. The TC105
normally operates in pulse width modulation mode
(PWM), but automatically switches to pulse frequency
modulation (PFM) at low output loads for greater
efficiency. Oscillator frequency is 300kHz, allowing use
of small (22μH) inductors. Supply current draw is only
102μA (max), and is reduced to less than 0.5μA when
the SHDN input is brought low. Regulator operation is
suspended during shutdown. The TC105 accepts a
maximum input voltage of 10V.
The TC105 is available in a small 5-Pin SOT-23A
package, occupies minimum board space and is ideal
for a wide range of applications.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
