TC1043 pdf datasheet
消耗积分:2 | 格式:rar | 大小:555 | 2008-08-07
久醉不醒
分享资料个
The TC1043 is a mixed-function device combining two
general purpose op amps, two general purpose comparators,
and a voltage reference in a single 16-Pin
package.
This increased integration allows the user to replace
two or three packages, saving space, lowering supply
current, and increasing system performance. A shutdown
input, SHDN, disables the op amps and one of
the comparators, placing their outputs in a high-impedance
state. The reference and one comparator stay
active in shutdown mode. Standby power consumption
is typically 6μA. Both the op amps and comparators
have rail-to-rail inputs and outputs which allows operation
from low supply voltages with large input and output
signal swings.
Packaged in a 16-Pin QSOP, the TC1043 is ideal for
applications requiring high integration, small size and
low power.
评论(0)
发评论
下载排行榜
