AAT2514,pdf datasheet(Dual Cha
消耗积分:3 | 格式:rar | 大小:223 | 2010-01-29
欲望都市
分享资料个
The AAT2514 SwitchReg™ is a dual channel current mode PWM DC-DC step-down converter operating at 1.5MHz constant frequency. The device is ideal for portable equipment
requiring two separate power supplies that need high current up to 600mA. The device operates from single-cell Lithium-ion batteries while still achieving over 96% efficiency. The AAT2514 also can run at 100% duty cycle for low dropout operation, extending battery life in
portable systems while light load operation provides very low output ripple for noise sensitive applications.
评论(0)
发评论
下载排行榜
