AAT1130,pdf datasheet(2.5MHz 4
消耗积分:5 | 格式:rar | 大小:221 | 2010-01-29
分享资料个
The AAT1130 SwitchReg™ is a member of AnalogicTech’s Total Power Management IC™ product family. The converter uses a predictive on-time, current-mode step-down control scheme that provides a fixed 2.5MHz switching frequency (under steady state conditions). It allows the control circuit to react nearly instantly in order to improve transient response and to enhance stability with the LC components as small as 1.0μH. The unique architecture
improves transient response while allowing tiny passive LC filter components. The high switching frequency (up to 2.5MHz) keeps output voltage ripple low.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
