AAT3190,pdf datasheet(Positive
消耗积分:3 | 格式:rar | 大小:221 | 2010-01-30
贾熹
分享资料个
The AAT3190 charge pump controller provides the regulated positive and negative voltage biases required by active matrix thin-film transistor (TFT) liquid-crystal displays (LCDs), charge-coupled device (CCD) sensors, and organic light emitting diodes (OLEDs). Two low-power charge pumps convert input supply voltages ranging from 2.7V to 5.5V into two independent output voltages.
评论(0)
发评论
下载排行榜
