AAT3200,pdf datasheet(OmniPowe
消耗积分:3 | 格式:rar | 大小:221 | 2010-01-30
分享资料个
The AAT3200 PowerLinear OmniPower lowdropout (LDO) linear regulator is ideal for systems
where a low-cost solution is required. This devicefeatures extremely low quiescent current, typically20μA. Dropout voltage is also very low, typically200mV. The AAT3200 has output short-circuit andover-current protection. In addition, the device hasan over-temperature protection circuit which willshut down the LDO regulator during extendedover-current events.
评论(0)
发评论
下载排行榜
