This project allows you to learn the communication systems in greater depth by giving you
the reins to play with it ! It contains the simulink files (*.mdl) which are block design
files of various communication systems such as AM, DSB-SC, FM, PLL, Data Acquisition, Digital
Data Transmission, PCM and Delta Modulation.
The idea here is to implement experiments of a traditional communication lab using Simulink.
Most of the block diagrams are self explanatory. More information of the system and their
implementation can be found in the word documents attached in the same directory of the lab.
请下载下面所有文件,下载完毕后解压缩到一个文件夹中使用。
全部1条评论
