MAX1626/MAX1627 pdf datasheet
消耗积分:5 | 格式:rar | 大小:444 | 2008-08-11
訾存贵
分享资料个
The MAX1626/MAX1627 step-down DC-DC switching
controllers provide high efficiency over loads ranging
from 1mA to more than 2A. A unique current-limited,
pulse-frequency-modulated (PFM) control scheme
operates with up to a 100% duty cycle, resulting in very
low dropout voltages. This control scheme eliminates
minimum load requirements and reduces the supply
current under light loads to 90μA (versus 2mA to 10mA
for common pulse-width modulation controllers).
These step-down controllers drive an external P-channel
MOSFET, allowing design flexibility for applications
to 12W or higher. Soft-start reduces current surges during
start-up. A high switching frequency (up to 300kHz)
and operation in continuous-conduction mode allow the
use of tiny surface-mount inductors. Output capacitor
requirements are also reduced, minimizing PC board
area and system costs.
The output voltage is preset at 5V or 3.3V for the
MAX1626 and adjustable for the MAX1627. Input voltages
can be up to 16.5V. The MAX1626/MAX1627 are
functional upgrades for the MAX1649/MAX1651.
________________________Applications
PCMCIA Power Supplies
Personal Digital Assistants
Hand-Held Computers
Portable Terminals
Low-Cost Notebook Computer Supplies
5V to 3.3V Green PC Applications
High-Efficiency Step-Down Regulation
Minimum-Component DC-DC Converters
Battery-Powered Applications
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
