// AT24C64 support functions using ATMEGA's TWI
// pin-WP is hard-wired to GND
// fuctions work better outside interrupt routines
// by MXH, 2003/07/30
#i nclude "DStruct.h"
#i nclude
// CONSTANTS DEFINITION FOR EEPROM
#define EEADDR 0
#define EEWR 0
#define EERD 1
// TWINT *NOT* set after STOP condition is sent
// check status?
// TWSTO is cleared by hardware
#define TwiStop() TWCR = _BV(TWINT) | _BV(TWEN) | _BV(TWSTO)
#define TwiStart() TWCR = _BV(TWINT) | _BV(TWEN) | _BV(TWSTA)
#define TWI_STATUS (TWSR & 0xF8)
BYTE byEEWait;
// implementation
BOOL EEPStart(BYTE addr, BOOL bWrite)
byEEWait = 10; // 90~100ms
poll_ack:
TwiStart();
while (!(TWCR & (1<
return FALSE;
if ((TWI_STATUS != TW_START)&&(TWI_STATUS != TW_REP_START))
goto poll_ack;
//byEEWait = 3; // 20~30ms
// send SLA+R/W
TWDR = addr | bWrite;
TWCR = (1<
TwiStop();
return FALSE;
if( EEWR == bWrite ){ // MT mode
//if(TWI_STATUS != TW_MT_SLA_ACK)
switch(TWI_STATUS){
case TW_MT_SLA_ACK:
break;
case TW_MT_SLA_NACK:
goto poll_ack;
default:
TwiStop();
return FALSE;
}else{ // MR mode
if(TWI_STATUS != TW_MR_SLA_ACK)
return FALSE;
return TRUE;
BYTE EEPWrite( WORD uiAddress, WORD uiLen, void *pBuf ) //using 0
unsigned int i,j,uiCnt;
if( uiLen == 0 ) return 0;
uiCnt = 0;
// uiEnd = uiAddress + uiLen;
i = uiAddress;
do{
if(!EEPStart(0xA0|EEADDR,EEWR)){ //PollAck() is built-in
return 0;
TWDR = (BYTE)((i>>8)&0x00ff); // MSB of address
TWCR = (1<
while (!(TWCR & (1<
return FALSE;
if(TWI_STATUS != TW_MT_DATA_ACK){
return FALSE;
TWDR = (BYTE)(i&0x00ff); // LSB of address
TWCR = (1<
while (!(TWCR & (1<
return FALSE;
return FALSE;
// write data
for( j=0; j<32; j++ ){
TWDR = ((BYTE*)pBuf)[uiCnt];
TWCR = (1<
while (!(TWCR & (1<
return FALSE;
return FALSE;
i++;
uiCnt++;
if(( 0 == i%32 )||( uiCnt == uiLen )){
TwiStop();
break;
}while( uiCnt < uiLen );
// while( !PollAck());
return 1;
BYTE EEPRead( WORD uiAddress, WORD uiLen, void *pBuf )
UINT i;
if ( uiLen == 0 ) return 0;
return 0; //↑
} // not RD but write device address to the chip
TWDR = (BYTE)(( uiAddress >> 8) & 0x00ff ); //((BYTE*)(&uiAddress))[1]; // MSB of address
TWCR = (1<
while (!(TWCR & (1<
return FALSE;
if (TWI_STATUS != TW_MT_DATA_ACK)
return FALSE;
TWDR = (BYTE)( uiAddress & 0x00ff ); //((BYTE*)(&uiAddress))[0]; // LSB of address
TWCR = (1<
while (!(TWCR & (1<
return FALSE;
return FALSE;
if(!EEPStart(0xA0+EEADDR,EERD)){ //PollAck()){
return 0; //↑
}// ??? how to read?
for ( i=0; i
while (!(TWCR & (1<
return FALSE;
if (TWI_STATUS != TW_MR_DATA_ACK)
return FALSE;
((BYTE*)pBuf)[i] = TWDR; // EEInByte();
TWCR = _BV(TWINT) | _BV(TWEN); // send NACK to indicate final byte
while (!(TWCR & (1<
return FALSE;
//if (TWI_STATUS != TW_MR_DATA_ACK)
// return FALSE;
TwiStop();
return 1;
附录:
;STC89C51读写AT24C64汇编程序
BITCNT EQU 42H
SDADR EQU 40H
SDA BIT P0.1
SCL BIT P0.0
ORG 0000H
JMP MAIN
ORG 0100H
MAIN:
MOV R7, #01010101B
ACALL WRITE_AT24C64
ACALL DELAY
ACALL READ_AT24C64
MOV P3, A
ACALL DELAY
;ACALL 显示、键盘子程序
JMP MAIN
DELAY:
MOV R6, #0FFH
DELAY0:
MOV R5, #0FFH
DELAY1:
DJNZ R5, DELAY1
DJNZ R6, DELAY0
RET
WRITE_AT24C64:
ACALL START ;发送起始条件
MOV A, #0A0H ;AT24C64总线地址
ACALL SENTBYTE ;发送AT24C64器件总线地址
JB F0, SENDRETURN ;出错返回
MOV R0, #SDADR ;取存储地址
MOV A, @R0
ACALL SENTBYTE
JB F0, SENDRETURN
INC R0
MOV A, @R0
ACALL SENTBYTE
JB F0, SENDRETURN
MOV A, R7
ACALL SENTBYTE ;发送一次数据
ACALL STOP ;发送停止条件
DELAY10:
MOV R4, #30H ;延时10mS等待数据写完
DELAY11:
MOV R3, #34H
DJNZ R3, $
DJNZ R4, DELAY11
SENDRETURN:
RET
READ_AT24C64: ;读AT24C64
ACALL START ;发送IC总线起始条件
MOV A, #0A0H
ACALL SENTBYTE ;AT24C64总线地址
JB F0, RCVRETURN ;出错返回
MOV A, @R0
INC R0
MOV A, @R0
JB F0, SENDRETURN
ACALL START ;发送IC总线重复起始条件
SETB ACC.0 ;取总线读操作数
ACALL SENTBYTE ;发送被控制总线地址
ACALL RCVBYTE ;接收数据
RCVRETURN:
RET
START:
SETB SDA ;发送起始条件的数据信号
NOP
SETB SCL ;发送起始条件的时钟信号
NOP
CLR SDA ;发送起始信号
NOP
CLR SCL ;准备发送或接收数据
RET
STOP:
CLR SDA ;发送停止条件的数据信号
NOP
SETB SCL ;发送停止条件的时钟信号
NOP
SETB SDA ;发送总线停止信号
NOP
RET
SENTBYTE: ;送数8位
MOV BITCNT,#08H
SENTB:
RLC A ;要发送的数据左移,发送入位C
MOV SDA, C
SETB SCL ;置时钟线为高,通知被控制开始接
收数据位
CLR SCL ;准备接收下一个数据位
DJNZ BITCNT,SENTB ;8位没发送完继续发送
SETB SDA ;8位发送完后释放数据线准备收应答位
SETB SCL ;开始接收应答信号
CLR F0 ;预先清发送数据出错标志
JNB SDA, ACKEND ;判断是否接收应答信号正常转ACKEND
SETB F0 ;未收到应答置位错误标志
ACKEND:
CLR SCL ;发送结束准备下次发送或接收数据
RET
RCVBYTE:
SETB SDA ;置数据线为输入方式
MOV BITCNT,#08H ;传送的数据长度为8位
RCV:
CLR SCL ;置时钟线为低,准备接收数据
SETB SCL ;置时钟线为高使数据线上数据有效
MOV C, SDA
RLC A ;接收的数据位放入ACC
DJNZ BITCNT,RCV ;8位没收完继续接收
CLR SCL ;8位接收完置时钟线和数据线
CLR SDA
SETB SDA ;接收非应答信号
SETB SCL ;置时钟线为高使应答位有效
SETB SDA
CLR SCL ;清时钟线以便发送停止条件
RET
;显示、键盘子程序
END
