Primary Applications
• Military Radar
• Transmit / Receive
Description
The TriQuint TGP2102 is a 5-bit digital phase shifter MMIC design using TriQuint’s proven 0.25μm power pHEMT process to support a variety of Ka-Band phased array applications including military radar.
The 5-bit design utilizes a compact topology that achieves a 1.41mm2 die area and high performance. The TGP2102 provides a 5-bit digital phase shift function with a nominal 7dB insertion loss and 5° RMS phase shift error over a bandwidth of 32-37GHz.
The TGP2102 requires a minimum of offchip components and operates with a - 5V control voltage. Each device is RF tested on-wafer to ensure performance compliance. The device is available in chip form.
下载资料需要登录,并消耗一定积分。
