Applications
• Phased Array Antenna Systems
• Satellite Communication Systems
• Electronic Warfare
General Description
TriQuint’s TGP2107 is a 6-bit, digital phase shifter fabricated on TriQuint’s high performance 0.15μm GaAs pHEMT process. It operates over 6 to 18 GHz and provides 360° of phase coverage with a LSB of 5.625°。 It also achieves a low RMS phase error of 5° with 8 dB of insertion loss over all states. The TGP2107 uses negative switch logic, eliminating the need for a reference voltage.
That, along with low insertion and a high degree of resolution makes the TGP2107 ideally suited for a variety of wideband phased array applications, including commercial and military radars, satellite-based communication systems and electronic warfare.
The device is lead-free and RoHS compliant.
