Applications
Wireless Infrastructure
LTE / WCDMA / CDMA / GSM
TDD or FDD systems
General Purpose Wireless
General Description
The TQC9307 is a digitally controlled variable gain amplifier (DVGA) with a broadband frequency range of 0.7 to 4.0 GHz.
The DVGA features high linearity and low noise while providing digital variable gain with a 31 dB of range in 1 dB steps through a serial mode control interface. At 3.5 GHz, the DVGA typically provides 13.3 dB gain, +40.5 dBm OIP3, +21 dBm P1dB and 3.5 dB noise figure. This combination of performance parameters makes the DVGA ideal for receiver applications requiring gain control with high IIP3 and low noise figure. In addition, the DVGA integrates a shutdown biasing capability to allow for easy operation for TDD applications.
The TQC9307 integrates a high performance digital step attenuator followed by a high linearity, broadband gain block. Both stages are internally matched to 50 Ohms and do not require any external matching components. The TQC9307 is packaged in a RoHS-compliant, compact 5x5 mm surface-mount leadless package.
下载资料需要登录,并消耗一定积分。
