The EMP891X series is a family of CMOS linear regulators, which include EMP8915 and EMP8916, featuring ultra-high power supply rejection ratio, low output voltage noise, low dropout voltage, low quiescent current and fast transient response. It guarantees delivery of 150mA output current, and supports preset 1.2V, 1.3V, 1.5V, 1.8V, 2.5V, 2.8V, 2.85V output voltage versions. Based on its low quiescent current consumption and its less than 1μA shutdown mode of logical operation, the EMP891X is ideal for battery-powered applications. The ground current increases only slightly in dropout, further prolonging the battery life. EMP891X provides fast turn-on by using dedicated circuitry to pre-charge an optional external bypass capacitor. This bypass capacitor is used to reduce the output voltage noise without adversely affecting the load transient response. The high power supply rejection ratio of the EMP891X holds well for low input voltages typically encountered in battery- operated systems. The regulator is stable with small ceramic capacitive loads (2.26F typical). Additional features include regulation fault detection, bandgap voltage reference, constant current limiting and thermal overload protection. Available in miniature
