TC3403 pdf datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-08-15
刘伟
分享资料个
The TC3403 is a low cost, low power analog-to-digital
converter based on Microchip’s Sigma-Delta technology.
It will perform 16-bit conversions (15-bit plus sign)
at up to eight per second. The TC3403 is optimized for
use as a microcontroller peripheral in low cost, battery
operated systems. A voltage reference is included, or
an external reference can be used. A VDD monitor with
a reset generator provides Power-on Reset and Brownout
protection while an extra threshold detector is
suitable for use as an early warning Power Fail
detector, or as a Wake-up Timer.
The TC3403’s 2-wire microPort™ digital interface is
used for starting conversions and for reading out the
data. Driving the SCLK line low starts a conversion.
After the conversion starts, each additional falling edge
(up to six) detected on SCLK for t4 seconds reduces
the A/D resolution by one bit and cuts conversion time
in half. After a conversion is completed, clocking the
SCLK line puts the MSB through LSB of the resulting
data word onto the SDAT line, much like a shift register.
The part automatically sleeps when not performing a
data conversion.
The TC3403 is available in a 16-Pin PDIP and a 16-Pin
QSOP package.
评论(0)
发评论
下载排行榜
