MAX5924, MAX5925, MAX5926,pdf
消耗积分:3 | 格式:rar | 大小:334 | 2010-05-01
分享资料个
The MAX5924/MAX5925/MAX5926 1V to 13.2V hot-swap
controllers allow the safe insertion and removal of circuit
cards into live backplanes. These devices hot swap supplies
ranging from 1V to 13.2V provided that the device
supply voltage, VCC, is at or above 2.25V and the hotswapped
supply, VS, does not exceed VCC.
The MAX5924/MAX5925/MAX5926 hot-swap controllers
limit the inrush current to the load and provide a circuitbreaker
function for overcurrent protection. The devices
operate with or without a sense resistor. When operating
without a sense resistor, load-probing circuitry
ensures a short circuit is not present during startup,
then gradually turns on the external MOSFET. After the
load probing is complete, on-chip comparators provide
overcurrent protection by monitoring the voltage drop
across the external MOSFET on-resistance. In the event
of a fault condition, the load is disconnected.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
