ABSTRACT A method for generating a symmetrical, bipolar, output swing voltage from a TI TLV56xx-family digital-to-analog converter (DAC) by using a bipolar operational amplifier (op amp), TLE2142, is presented. The resulting output voltage has a wide range that is limited only by the choice of op amp used for conditioning the DAC output signal. The example in this report realizes an output voltage range of ±13.8 V for a 10-kΩ load.
