a3952 pdf datasheet (FULL-BRID
消耗积分:5 | 格式:rar | 大小:555 | 2008-08-28
分享资料个
Designed for bidirectional pulse-width modulated current control of
inductive loads, the A3952S– is capable of continuous output currents
to ±2 A and operating voltages to 50 V. Internal fixed off-time PWM
current-control circuitry can be used to regulate the maximum load
current to a desired value. The peak load current limit is set by the
user’s selection of an input reference voltage and external sensing
resistor. The fixed OFF-time pulse duration is set by a user-selected
external RC timing network. Internal circuit protection includes thermal
shutdown with hysteresis, transient suppression diodes, and crossovercurrent
protection. Special power-up sequencing is not required.
评论(0)
发评论
下载排行榜
