提高电网功率因数节能效果分析
消耗积分:5 | 格式:rar | 大小:344 | 2010-06-14
贾飞小
分享资料个
由于感性负荷的比例大,造成供电电网的功率因数低,损耗大。本文分析和计算了加装无功补偿装置后的高压供电线路和主变压器的节能效果。
〔关键词〕功率因数;线路;变压器;损耗
Abstract:Because of inductance loading is larger, the power factors of electrified wire netting are lower and the loss is higher. The results of energy saving are analysed and calculated to high voltage circuit and main transformer after installing inefficiency power compensation apparatus.
Key words: power factor; circuit; transformer; loss
评论(0)
发评论
下载排行榜
