2790产品说明书 SourceMeter Airbag T
消耗积分:2 | 格式:rar | 大小:716 | 2010-06-21
分享资料个
The Model 2790 SourceMeter Switch System is a high voltage, multichannel
resistance measurement solution that speeds and simplifies electrical
checks of airbag inflators and a variety of other automotive electrical
test applications. It is the only commercial instrument that combines all
the sourcing, measurement, and signal routing capabilities required to
measure insulation resistance and conductor continuity in one compact,
affordable package. Through the use of plug-in source/switch modules, the
Model 2790 provides programmable high voltage and low current sourcing,
plus multichannel switching support. This unique combination of
capabilities establishes a new standard for price and performance in airbag
inflator and other test applications.
评论(0)
发评论
下载排行榜
