A Low Cost Design Solution - D
消耗积分:2 | 格式:rar | 大小:642 | 2010-06-29
分享资料个
Abstract:  As  per  international  agency  regulation  (IEC  1000-3-2/EN  61000-3-2)  and  market
expectation,  it  is  important  to reduce current harmonics  in  the AC  line current drawn by SMPS/ UPS
connected to AC Mains as source and also it is desired by the user to deliver maximum power output
by achieving unity power factor. To achieve the above objectives in SMPS/ UPS, APFC is required to
be  implemented as  front end power  interface between SMPS/UPS and AC Mains  source. This  study
explores low cost design solution – DSP based APFC for Industry involved in manufacturing/supply of
SMPS/UPS.
Key words:  Digital signal processor (DSP), active power factor corrector (APFC), sinusoidal current
(no  harmonics),  power  factor  (PF),  voltage  mode  controller,  current  mode  controller,
switching mode power supply (SMPS), un-interrupted power supply (UPS)
评论(0)
发评论
下载排行榜
